8000 lumen led prime flashlite
JLumens
wi
Here is a video with parts list for a 8000 lumen led flashlite.this is a mule(wide beam) and is the cheapest way to make a 8000 lumen led flashlite. parts list includes optional lens and ac power suppy
parts list
A 8000 lumen super bright led flashlight.Worlds brightest led. Ez to make, is brighter and cheaper to make about a 100$ to make.can use 6 volt lights battery pack will fit. parts list comeing.PARTS parts parts
The prime 8000 led http://dx.com/p/prime-100w-8000lm-led-emitter-metal-plate-pure-white-42806~r.87047508
The reflector http://dx.com/p/20-100w-silver-plated-plastic-smooth-reflector-58mm-39963~r.87047508
3 battery holder http://dx.com/p/11-1v-3-x-18650-battery-holder-case-box-with-leads-100996~r.87047508
2 battery holder http://dx.com/p/7-4v-2-x-18650-battery-holder-case-box-with-leads-100997~r.87047508
Heat sink http://dx.com/p/universal-southbrid...=2&m=3&r=2&k=1&t=1&s=13614&u=48616~r.87047508
Round heat sink http://dx.com/p/professional-heatsink-intel-cpu-cooler-fan-125417~r.87047508
Heat sink glue http://dx.com/p/fujik-silicone-ther...p=2&m=2&r=3&k=1&t=1&s=65465&u=4579~r.87047508
18650 battery http://dx.com/p/ultrafire-3-7v-18650-2400mah-battery-1213~r.87047508
Lens http://dx.com/p/59mm-20mm-15-120-degree-99-transmittance-glass-optic-13569~r.87047508
AC power suppy http://dx.com/p/3-0a-100w-power-con...=2&m=2&r=3&k=1&t=1&s=42806&u=47306~r.87047508
try 2 http://www.youtube.com/watch?v=yyplgNRCCUQ&feature=share&list=UUxsSd06ajr-AUpkw0-D6SyA
and enbed <iframe width="560" height="315" src="http://www.youtube.com/embed/yyplgNRCCUQ?list=UUxsSd06ajr-AUpkw0-D6SyA" frameborder="0" allowfullscreen></iframe>
Interesting approach. A lens/reflector would have been a nice touch, as you could see the yellow plastic was glowing pretty strongly.
:D
Nice, BUT: Ugg at the battery setup. 8S with at least 4 different types of 18650 cells is yelling to the heavens for trouble, especially as you also have quite a bit of current.
Especially since most of those look like unprotected batteries and since they are just connected "direct drive" without a driver to limit current draw you are asking for trouble. Also I'd be curious to see if that cheap ebay led can put out an actual 8000 lumens, I would have gone with a bridgelux led, you can get ones that put out 9000 lumens. I have one but so far haven't gotten around to building a power supply that can put out 34 volts at 2.8 amps.
Thumbs up for the insanely bright flashlight though, just be carefull....
Especially since I have one but so far haven't gotten around to building a power supply that can put out 34 volts at 2.8 amps.
The Taskled hbflex is pushing up to 50v @ 3a with levels and is a boost driver so you can use less batteries (up to 24v). A 5s Lipo pack is ideal to get some runtime.
The video makes a false claim regarding its 100w led (array) being the worlds most powerful. You can get Citizen COB leds that claim 17600 lumens, (probably 14000 at 85c) assuming their literature is true. They consume 184 watts.
its been hard to find a refector. but found a lens. whating for it now
why dont you leave a link for your claim? and so i can use it in my next diy.
no one is making 100watt dc prower contoler..
Welp, this is pretty crazy! :D
Also worth noting that LED has dropped in price to $53.20 according to DX right now.
