Hi folks,
Everybody remembers the 2x168 Stinger upgrading kit
This is 3 cell version kit that will allow you to enjoy your Stinger brightness while get one full hour burn time per charge. This kit will increase length of Stinger about 70mm. If you are using Stinger HP models, use WA1318, 1331 or 1166 bulb and if you are using non HP models, use my axial fillament 22 watt bulb.
Remember, both Super Stinger and Ultra Stinger use 10 watt bulbs while you can use 20 watt bulbs with this set up. So brightness of your Stinger HP will be even more than UltraStinger and brightness of your non HP Stinger will be more than SuperStinger while size/weight is smaller/lighter and burn time is same (one hour) or even more with WA1306 bulb. For maximum brightness WA1318 is recommended. (HP models only)
Simply unscrew and remove Stainless steel negative contact ring off from anodized aluminum tube. Drop 3 Pila 168A or 168S negative side down, then replace steel cap and istall in the Stinger.
No tools or skills needed and won't take more than 2 minutes. Best of all, it's allways reversable.
Installing Pila batteries.
Installing stainless steel negative cap.
Battery adapter kit will work instead of original battery and tail cap.
Will not work on XT models.
Requires three Pila 168A (recommended) or three 168S or even three 17670
Current draw is about 2 Amps and burn time with 168A about 60 minutes using 1318, 1331 or 1166 bulb.
I also offer Boro lens service FOR NON HP MODELS. Just send your Stinger head to my Paypal address, and I will send it back along with adapter after installed Boro lens or get a brand new standard head with Boro lens installed.
I have got some axial fillament bulb which is made by Carley Lamps exclusively for Fivemega. This will give you beautiful circle hot spot with nice side spill.
$34 battery adapter
$6 1166 bulb (OUT OF STOCK)
$6 1331 bulb
$12 axial 22 watt bulb (FOR NON HP MODELS)
$12 Boro lens service (FOR NON HP MODELS)
$22 Boro lens installed new head/reflector (FOR NON HP MODELS)
$122 New Stinger flashlight with adapter, installed Boro lens and axial bulb (No battery or charger included)
$3 shipping to all 50 States (with delivery confirmation)
$6 shipping internationaly. (no confirmation available)
Paypal: DO NOT PAY
Please post your detailed request here followed by paypal and include your CPF ID in paypal. For example:
for 1 adapter, 1 Axial and boro service.
Any comment or recommendation welcome and appreciated.
$34 battery adapter
$6 1331 bulb
Paypal: DO NOT PAY
