91-96 buick roadmaster wagon
old_
How bad are the head lights? I believe they share lights with the 91-96 caprice. I've always liked the roadmaster wagon and am looking at getting a low mileage '95 that just became available. Is there a housing upgrade available, possibly from an overseas market roadmaster?
thanks!
Very bad. They are cheap, nasty, poorly-focused items that take the intrinsically bad 9004 (HB1) bulb. And the circuitry is underspecified, so even those weak bulbs are underfed. That part's easy to fix with a relay kit, and you can improve on the bulb situation somewhat by installing the best available 9004s (GE Night Hawk Platinum 9004NHP), and of course you should make sure the lamps are correctly aimed. But if you need more than that, and you very well might, then you'd need to look at installing auxiliary lamps.
There is no safe, effective, legal way to put a "Xenon" (HID) light source, or any other light source that is not a 9004 bulb, in those headlamps.
No, you're thinking of the Oldsmobile Custom Cruiser. The Buick Roadmaster had its own headlamps not used on any other vehicle.
No. The Caprice was exported, but not the Roadmaster. There used to be UN-spec headlamps for the Caprice, with H4 bulbs and glass lenses, but they were discontinued years ago and have been unavailable for quite some time -- and they would not fit a Roadmaster.
Thats a shame, because the Roadmaster is a great highway bruiser...I mean cruiser :) And that, of course, is where good lights really, really come into play.
Are you sure the Roadmaster (estate) wagon does not share headlights with the Caprice? I know the Roadmaster sedan is different but I thought all of the last generation B-body wagons, the Caprice, and the Impala SS shared headlights.
Ah, looks like you're right: the Roadmaster wagon uses '91-'96 Caprice headlamps.
But all the previous comments still apply. :-(
Hey at least it's a big car with room to mount aux lights and the alternator to run them. In the absence of those export Caprice lights, a pair of auxiliary low beams and a pair of driving lights may be the best way to keep this freeway cruiser safely on the superslab.
