We've had the topic of metalizing the back of a luxeon optic with some kind of chroming come up many times here on CPF. The generally accepted conclusion is that it would do more harm than good, as the optics are designed specifically around the index of refraction between the optic material and air. Any change in the optical properties from modifying the surface (i.e., buy metalizing it) would result in a change in how the optic works.
Larry (tvodrd) sent me a couple of optics to do a comparative test. One is a bone stock 30mm optic, while the other has had the backside metalized. The metalized optic also had the outer rim cut off, but that won't affect the optical properties at all.
Here are the contenders (normal on the left, metalized on the right):
Here's the mounting system I used:
The LED was a Luxeon III star, bin TY0L, run at 700mA.
Some quick beamshots - these were done by placing a white board about 24" away.
These shots at ISO50, daylight While balance, F/3.5
Normal on the left, metalized on the right
Shutter speed: 1/50
Shutter speed: 1/250
Shutter speed: 1/1000
Finally, useful "across the garage" shots (distance of 15 feet) (same camera settings for both shots)
It looks like the metalized optic has a dimmer hotspot and slightly wider beam angle.
Center beam measurements (taken at a distance of 1 meter with a MeterMan LM631 light meter):
Normal: 2860 lux
Metalized: 1147 lux
I used my beam angle measurement test rig to characterize the beam from both optics. Here are the results:
So indeed, the metalized does spread the beam out somewhat, but does so at a severe weakening of the hotspot. The wider beam angle is more noticable in actual viewing than the graph would indicate.
Shutter speed: 1/50
Normal: 2860 lux
Metalized: 1147 lux
