Blackout + M@G85 + people = :)
setherd
Largo, FL
I was at a friends house tonight and had my m@g85 in the car. the power went out for about 20 minutes. I had my arcAAA on my keychain and a 35mcd keychainlight as well.
...then I said hang on a sec. I went to my car and got my mag85 and SL TL3.
by this time my friend was out in the street talking with a couple of neighbors.
I turned on the [email protected] the cries of shock..."what the heck is that?"
It was almost as if i had an enormous ***** :D
flashlite
PA
setherd said:
ahhh the cries of shock..."what the heck is that?"
I don't have a Mag85 but I can attest to the analogy. That is the reacion you get
paulr
"Is that a USL in your pocket or are you just glad to see me?" </Mae West> :D
Hookd_On_Photons
I could make a comment about large size and short runtime, but then people would probably think it's because I'm packing a Dorcy AAA down there. Or a FireFli. :whistle:
I wonder how they would have reacted to a Thor 15 million candlepower spotlight? :D
missionaryman
Sydney, Australia
I had a similar situation in New Guinea with my MAG951 - try it in a less entertained country and see the reaction you get. I think if the lights came back on I'd be signing autographs...
LeDfLaShEr
I wish I had a Mag85.....or a huge ***** for that matter....either would be fine.
LowBat
San Jose, CA
Quote:
Pardon me while I whip this out -Blazing Saddles
That was the late Cleavon Little. How about a slight twist on another quote from the same movie by the late Madeline Kahn.
"Is it twue what they say about you flashaholics?" zip "It's twue it's twue!"
scaredofthedark
TX
how long do the bulbs on the mag85 last? i want to do the mod but i need more info on bat life and bulb life.
Geologist
Earth
I hadn't seen that film in ages and watched the extended version a couple nights ago. Man oh Man! Mel Brooks is da man - but how he got away was some of that is beyond me!
setherd
Largo, FL
That I don't know. I'm still on my first one.
Hookd_On_Photons
Voltage: 9.6
Wattage: 30.24
Current (amps): 3.15
Filament Diameter (mm): 0.863
Filament Length (mm): 2.921
Bulb Diameter (mm): 7.11
Lamp Fill: Halogen-Krypton
Wire Terminal: 01185
Lamp Size: T2-1/4
Opaque Tip: No
MSCP: 65.0
Correlated Color Temp.: 3,370
Envelope Type: Hemispherical
Life (Hours): 50
Lumens: 816.81
Lamp Configuration: S
Efficacy: 27.01
http://www.walamp.com/lpd/webstore/detail.tpl?partnumber=01185-U
SilverFox
Bellingham WA
Hello Scaredofthedark,
9 2500 mAh cells in series will give you
9 * 1.2 volts = 10.8 volts,
but since they are in series you are still at 2500 mAh of capacity.
To figure run time, take the 2500 mAh and multiply it by 0.8. This allows for the drop in capacity at high current rates. So, now we have
2500 mAh X 0.8 = 2000 effective mAh
The Mag85 draws 3150 mA, so we divide capacity by draw and get
2000 mAh / 3150 mA = 0.635 hours or about 38 minutes.
Tom
