A little advice / help?
bcoots
Before I actually "got into" lights I ended up buying a Streamlight Protac HL light. Lived with it for quite some time and honestly have enjoyed it to be honest with you. Until now. After getting and digging into lights a little deeper, I've found out that I can't use rechargeable batteries in this light. Primary batteries ='s $$$. So it's on it's last set of CR124A's that I have in the house. This leads me to my dilemma. I can 1. keep purchasing these primary batteries forever and ever amen. or 2. bite the bullet and replace this light with another one that can use some of the 10 18650 batteries I bought for my TN30. I'm going to do the checklist just to see what light comes up for what price points. I don't particularly care if it uses one or two batteries. Decisions!
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__XXX__This will be mail-order or Online
NOTE! I use AMAZON a lot! So if it's on there at a decent price I'd prefer that, but if not, I'm all ears.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____I don't know yet
____Up to $25.
_))XX___Up to $50.
__XXX__Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__XXX___I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
__XXX__MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don’t know/I don't care.
NOTE: It's replacing the Streamlight Protac HL
5) Emitter/Light source:
__XXX__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__XX__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
__XX__I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
_XXX___I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
__XXX__I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
__XXX__I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
__XXX__I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
__XXX__Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
__XXX__Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__XXX__5-20 yards/meters (check out a noise in the backyard)
__XXX__30-50 yards/meters (I have a big backyard)
__XXX__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
____150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
__XX__90-120 minutes (Runtime is moderately important, but still not critical)
_X___3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
__XX__Slightly Important (Walks around the neighborhood).
__XXX__Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don’t know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
_XXX___I don't care.
____I don’t know.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ---...--- emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
__XXX__I don’t care.
____I don’t know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
_XXX__I don’t care.
____I don’t know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
__XXX__IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
__XX__In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
Although you didn't ask about rechargeable battery solutions, I will point out that you can use your ProTac HL with 2 x LiFePO4 RCR123 rechargeable batteries. They are almost a direct replacement for primary 123A cells but do provide a shorter runtime. Unfortunately the ProTac will not work with 1x17670 lithium-ion (or at least mine won't).
As far as suggestions are concerned, the Malkoff MD2 is always a popular choice with the M61 drop-in module. It doesn't throw quite as far as you specified, as it has a more general purpose beam, but it can still reach out a fair distance. I have very little experience with other brands of 18650 lights so I'm afraid that's all I can recommend.
Malkoff is always a solid choice. Good lights that can use 18650 cells and also made by Fenix, FourSevens, and Klarus. I have personal experience with all of these brands except Fenix, and all have a good reputation.
