Katherine Alicia
This isn`t really intended for the established flashlight modder, but I get asked quite a bit about converting old incan lights into something more "Modern" namely Li-Ion and LED usage.
So I`m sharing a simple method that I use with ordinary easy to find bits and require some soldering experience.
The bulbs for most retro lights will either be an E10 MES, or a PR13.5, there`s plenty of different LED dropins for those, you can even use maglite LED dropins for the PR type socket, personally I prefer multi-emitter dropins for these lights, you get more light with less heat (losing heat is big problem with these lights).for the battery you have to do a bit of DIY, it`ll involve cutting a suitable cardboard tube to fit either a protected 18650 or 21700 (you must use protected cells!), and then a way to make a spacer so it`s long enough to connect at both ends. I use brass PCB standoffs with a penny soldered to each end (you can adjust the length then). OR, you can buy some AAA to C cell adaptors and fill them with 10440`s it`s expensive this way and takes a while comes charging time because you`ll have 8 of them to do! plus they`re not protected (I don`t recommend this method but I have done it).
I`ll put up a picture link to show what I mean
this is a 2xC cell light from the 60`s with an assortment of different LED dropin types.
There Are other ways to do this but propper adaptors for 18650/21700 to 2xC or 2xD are hard to find or often expensive, and not everyone has a 3D printer.
Hopfully this may help someone out in the future!
