I'm looking to get a Fenix AA, probably a LD10. I was just wondering if this light is able to be put on a keychain. I carry my EDC on a key caddie w/keys seperate. My gerber light has a hole in the top which a split ring can connect through.
I'm more of a car nut than a flashlight nut, and heavy keychains have led to many ignition switch failures. So yes it's capable, but I would recommend not hanging it from your ignition.
Sorry, I should have clarified. The AAA Fenix that I've used, EO1, came with a split ring. I put a Photon clip on there. The LD10 on Fenix Store doesn't mention a split ring, rather a lanyard. I assume the lanyard connects by string.
My L1D Q5 accepts a Size 6 split ring in one of the lanyard holes. It can then be hooked to a keychain, paracord lanyard, and can even still tail stand. You should be able to fit a Size 6 split ring to a LD10 as well.
