AA Problem
Status
Not open for further replies.
Undark
Germany
Hi,
just got another AA - but it isn't working as expected...
The light was on, I turned it off and now it won't come
on again...
I measured 104mA when the battery is connected to the head,
the battery is over 1.5V... What can I do?
Is this one of those PCB-problematic AAs?
Thanks,
Undark
If it has the bad chip, it will eventually come on after several minutes. The chip would cause it to not come on again after less than a minute. It also would cause it not to come on with weak batteries or in cold temperatures.
For your light, I would recommend checking the positive and especially the negative contact surfaces for corrosion.
I hope this helps.
Peter
The contacts seem to be ok. The LED even doesn't turn on if I
connect the postitive battery contact directly to the solder
blob on the head and the negative one with the threads...
Any suggestions?
Thanks!
I have the same problem with my AA. Using a lithium AA solved the problem, albeit at a price.
Status
