About Energizer e2 alkaline and e2 lithium
TimeTraveller
Houston, TX
I've browsed the Energizer technical info page, and it stays that e2 AA alkaline's current is 3125mA, while e2 AA lithium is only 2900mA. How come it's like that? Shouldn't the lithium one have more power? And how will it affect the flashlights, for example, Inretech 2AA or PT Surge? Thanks for any answer!
Lithiums have very low internal resistance and keep their voltage relatively flat until they're about empty. The mAH rating for alkalines is based on very low current drain, like in a quartz clock or pocket radio. At higher current, like in a powerful flashlight, you get a fraction of that mAH. With lithiums, you get pretty much what it says, even at high current. At medium current (like in a 5mm LED light, say a CMG Ultra), lithium does a bit better than alkaline but its main advantage is cold weather performance and long shelf life.
At high current drain and when cold weather and shelf life aren't too much of an issue, NiMH (rechargeable) is the best bet. It will outperform alkaline substantially and it has by far the lowest operating cost, and is the most environmentally friendly.
