Yesterday (Friday) I received my 12 AccuEvolution D's and 12 C's as well as a Titanium MD-3000 charger in the mail. I also received a Maha MH-C808 on monday.
This is my first delve into C and D NiMh cells and chargers, having used AA & AAA Enloops and Duraloops and 2 BC-9009's for some years.
Concerned about the quality of these cells, I did some experimenting. The D cells I received look like the left hand side cell in the image in post #26.
I read the voltages of 4 C's and 2 D's out the pack, under a 2 ohm load, and then after charging (hot off the charger) and resting.
I charged 4 C cells in the MD-3000 for about 2hours. The cells from the outer bays were cool on termination, but the inner two were warm. I noted that the charger was warm in the centre, and attributed the battery warmth to the charger heating up.
After doing some voltage testing, I then charged - or at least started charging - 2 D cells on the outer bays of the MD-3000. The centre of the charger was again warm after an hour. After about 3 hours of charging, 11:30pm last night, the D cells were still cool, but the plastic in the centre of the charger was too hot to comfortably touch, and on closer inspection, I noticed that the plastic had actually deformed from the heat.
That freaked me out a bit, and I aborted immediately. I did not get to sleep for a while after the near meltdown.
This morning, I continued charging the 2 D cells in the C808. One cell (D-A2) terminated while cool after 45 minutes at 1.43V. On re-insertion it only showed 2 of 3 bars, and terminated again ~20 minutes later at 1.46V and only slightly warm. The other cell (DA-1) failed to terminate after 1h30, and was very warm (had been for 1/2 hour), so I pulled it. It read 1.44V. I am not sure how the C808 terminates, but the peak voltage due to the pulsed charge current was getting slightly lower with time, and the cell getting warmer. I do not know when/if it would have terminated, if I was being impatient, or if it was a cell/charger issue. More time and testing may shed some light.
C-cells
Voltage Load V V After 1h30 14h00 17h25 18h20
from Pack 2 ohm charge rest rest rest rest
C-A1 1.295 1.285 1.464 1.436 1.408 1.404 1.401
C-A2 1.296 1.285 1.466 1.436 1.408 1.405 1.402
C-A3 1.288 1.280 1.464 1.431 1.405 1.402 1.399
C-A4 1.294 1.283 1.462 1.436 1.410 1.404 1.403
D-Cells
Voltage Load V V After 1h10 1h30 2h15 3h00 4h15 5h15
from Pack 2 ohm charge rest rest rest rest rest rest
D-A1 1.285 1.271 1.445(hot) 1.406 1.402 1.398 1.396 1.391 1.389
D-A2 1.286 1.275 1.460 1.408 1.405 1.401 1.398 1.394 1.391
For pre-charged cells, their voltage out the pack was quite low (C and D), and the fact that the C's charged for 2 hours, and the D's for approx 3 + 1 hours, bears with the fact that they were indeed more than half empty.
Not very scientific or conclusive, what with 2 different chargers and the limited cells I tested, but the D cells do seem to sag slightly quicker after charging. Than the C's. I do not have any other C/D NiHM cells to compare these againt, so I do not know if these figures are good or bad.
The fact that the one D cell did not seem to want to terminate and was heading towards hot also does not look good.
I will keep track of these cells, and charge some more C's and D's up later on the C808. Unfortunately I do not have any equipment to measure remaining capacity, short of measuring runtime under load.
The MD-3000 is getting an early retirement after its fiasco last night. Hopefully it can go back for replacement, but i fear that with the cost of shipping it will not be worth it.
