TaschenlampeMann
As my collection of 1x RCR123 lights grows I have some lights that require the 3 volt cells and some that will take the 3.7 volt cells. Having two different kinds of chargers was a pain, especially when traveling.
So.....
I thought of building an adapter that would drop the 4.2v max voltage from my standard Nano charger down to around 3.7 volts max to charge the 3 volt cells. The adapter consists of a germanium diode (for the slightly lower forward voltage drop than a silicon diode) soldered to a circular piece of double sided copper-clad circuit board.
When charging 3v cells in the 3.7 volt Nano charger, I simply slide the diode assembly between the charger terminal and the battery + terminal...being careful to observe the polarity of the diode.
At the end of the charge cycle on a 3v cell. The Nano charger is putting out about 4.1 volts and there is 3.7 volts on the battery + terminal.
Any thoughts or comments? Is this a valid way to avoid buying and carrying two different chargers?
So.....
