Adhesives
m4a1usr
Washington State
I did a basic search and didn't find a satisfactory answer about this topic. Does anyone have a preferred adhesive they use when bonding the LED (bin?) to the housing (pill?). Just so I'm clear I'm referring to the part you solder the wires to coming off the regulator board. Forgive a newbie for such a dumb question. Thanks, John
It still comes off with some effort and alcohol.
It's not too hard to pop whatever you glued off and then once you do that you'll have to rub hard with alcohol.
Cured Arctic Alumina can be softened with heat.
I make my own thermal epoxy with Devcon 30 minute epoxy and alumina oxide used in a 50/50 ratio.
