charliek,
The Q3J is a 1 watt high dome luxeon. These are popular right now because they can be had for a very good price and are very white and bright. I have not seen a bad one and have used over 8 of them. They are very consistent. Hotbeam is selling them right now in the B/S/T forum. You should get a couple if you're gonna start modding. I try to keep 3 or 4 around just in case I get an idea. As far as what Q3J means:
"Q" is the flux. The higher the letter, the brighter the light of the luxeon at a given current. (Spec is 350mA) I think the Q is good for around 40 lumens. There are "R" ranked LED's floating around, but they have been inconsistent, in my experience, in brightness and color.
The "3" (usually subject to the luxeon lottery) is the designation of the color. 1=green tint, 2=greenish/yellow tint (the R2's I've seen have been on the yellow side and one was greenish), 3=white, 4=bluish, 5=purple (just a note, but in my experience the 2's do better in outdoor situations. The warmer light just cuts through the dark like a knife)
The "J" refers to the forward voltage. In this case 3.27-3.51 volts. The higher the letter, the higher the forward voltage. The lowest I've seen in a really bright luxeon is an "H" which is 3.03 - 3.27 volts. Generally speaking, you would want an LED with a low forward voltage because they provide more runtime. If you plan to direct drive, you may want something with a higher forward voltage to reduce the chance of cooking the LED.
I have a KL1 that I modded with a Q3J and a Downboy 700 circuit. It is very bright and runs for over two hours on a single 3.7v Pila rechargeable battery. I also have the
M@g 3D with Q3J that I'm running in direct drive with no resistors. I can't say how long it will last, but many people push one watters to 1A without trouble. The
M@g moves around ~950mA through the LED using 3 alkaline D cells. I haven't tried Nimh and probably won't because it's my understanding that Nimh batts have lower internal resistance and will likely result in a current flow in excess of 1A. Someone correct me if I'm wrong.
