Hey fellas,
After a recommendation on a couple of lights, a couple for myself and one for my father...
So, first up, is something to replace the Led Lenser P7 my father is currently mainly using for work.
I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $100.
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____Every day carry medium (4-7 inches).
____Holster carry.
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn) (Preference is AA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.) (may consider)
8) How much genuine out the front (OTF)light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible). (brightness adjustable with the following)
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens)
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____30-50 yards/meters (I have a big backyard) (more is always handy)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
12) Switch Type and location (choose all that apply):
____I don't care. but something that can tail stand would be handy.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I don’t care.
(preferably more than 2 but nothing rediculous).
14)Material/Finish/Coating
____I don’t care.
Something tough enough to handle drops and being thrown around a bit.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____Pocket/belt clip
____Holster
_________________________________________________________________________________________________________________________________
Thats that one, now one for myself, one to put in a tool wrap for my motorbike.
____I will be mail-ordering or buying online, so this doesn't matter.
____Less than $100. preferably less but can do this if I must.
3) Format:
____Every day carry small (2-4 inches).
6) Manufacturer:
not too fussed.
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
would prefer AA, due to being easier to find.
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to walk around an unlit rural area (50-150 lumens). (more is always nice)
____30-60 minutes (I have plenty of batteries just ready to be changed)
____I don't care.
____I don’t care.(nothing overly complicated but reliable).
____I don’t care.
none really.
And now, lastly another, for myself, to replace my Quark AA2, which at times is a bit temperament.
____Less than $100.
3) Format:
____Holster carry.
6) Manufacturer:
(not too fussed)
Am fine from AA, RCR123-18650
____I want to illuminate my entire backyard or a campsite (150-300 lumens). (again, more is nice but ultimately, something a bit better than the Quark AA2)
____50-150 yards/meters (I live in a very rural area/farm with wide open spaces) (Not super important to have this much throw but would be nice)
____I don't care.
____I don’t care.
Preferably without a million different levels and strobes etc...
Something quick and easy to use.
14)Material/Finish/Coating nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don’t care.
___Pocket/belt clip
____Holster
(wont say no to any more extras though).
And I think that about sums it up.
Would appreciate any help.
____Less than $100.
3) Format:
____Holster carry.
6) Manufacturer:
____I don’t care.
____I don’t care.
____Holster
3) Format:
6) Manufacturer:
not too fussed.
____I don't care.
____I don’t care.
none really.
____Less than $100.
3) Format:
____Holster carry.
6) Manufacturer:
(not too fussed)
____I don't care.
____I don’t care.
____I don’t care.
___Pocket/belt clip
____Holster
