Greetings. Please, treat me as a complete idiot when it comes to LED and battery mods. I'm learning so much, yet, so far to become somewhat of a amateur LED light tinkerer.
I have an ancient Blackburn X3 headlight system that the battery pack finally crapped out. Well, as an idiot trying to figure things out, I use my rotor tools, split the case apart, and examine the inner working parts. I read previous posts about the X3/X6/X8 mods, but not much on the battery pack connection to the existing circuit board/driver itself. So, out of curiosity, I took the same 5 NiMH, hooked it up in series, took the 4-pins battery pack connector, did the exact hookup as the original layout, and the result is no power. So, I believe the driver for this system is dead.
So, out of curiosity, I grabbed 4 of the NiMH battery, shoved them in the 4-battery housing in series, stripped the wire cable going into the LED (white/red/black), where red is the main power, black is ground, and white is :confused: I'm presuming it's designed for a power step down of some type to toggle between High/Med/Low/Flash. Ran the battery pack directly to the LED with power source pos to red, power source negative to black. LED lights up. A couple of question:
1. 4 NiMH in series measured at 5.4V on the meter, and total of 2 forward Amps. Would the Luxeon III LED be okay in the long run just running the battery straight through like this? The LED is rated at 700mA, 6V? I can tell the light is a bit dimmer at high than before. Should I use the 5 battery housing pack instead of 4 and solder a 700mA resistor to the battery pack?
2. Since most headlights have toggle switch at the top, is the white wire can be used somehow as a toggle switch like before with a new circuit board, or rigging it up with some cheap mod for different light setting or am I screwed, and just use a on/off switch for the LED?
3. I got a 7.4V, 5.2AH lithium ion pack from a toy. Should I use a regulator, resistor, capacitor combo for the LED or should I attempt to purchase a multi-power sources driver for 6V at 1A for the lithium ion pack, as well as the seal lead acid 12V 14AH battery for the long cycling trek with my family ahead?
* I will purchase the Cree/SSP LED later to replace the one in the Blackburn housing like I saw earlier. That will be for the future projects once I'm confident with this one.
Any info is greatly appreciated! Like I said, I'm a moronic newb just trying to start out his tinkering in the LED and power pack areas.
Leo
Leo
