angle plates... sort of.
bretti_kivi
Lahti, Finland
Over on DIYMA, I saw a pic a while back of a carpenter using something that looked remarkably like an angle plate with extensions - so it was forming a support for the corner of a box.
Since I need some angle plates anyway for other stuff, I figure I'd ask; any idea what this would be called and / or where I could find one, preferably online?
thanks!
Bret
It sounds like you saw a box angle or a box table:
Most of these are huge ... even a tiny one will be at least 18" (450 mm) x 26" (650 mm) x 16" (400 mm) ... and weigh over 600# (300 kg). We used one on the radial drill, and that table was larger ... just under 2000# (820 kg).
Since you probably need something smaller ( :crackup: ) cast iron V-blocks come in every size and shape you can imagine, from tiny to X-large.
There's an Eron B200 on eBay, one of their larger ones at 50# (22 kg)
http://cgi.ebay.com/ERON-CAST-IRON-...ZBI_Tool_Work_Holding?_trksid=p3286.m20.l1116
