Hey everyone. I've been lurking here off and on for a few weeks trying to learn and finally decided it's time to join. Recently, I've been thinking it's time I get a new, quality flashlight, something different from the cheap incan I got from work, but I'm finding myself becoming a bit overwhelmed. Here is my completed questionnaire...
Recommend a light for a newbie
I guess I want a general purpose light that can serve many functions. I would like to use it when I go backpacking/camping but I will also be using it around the house and in other situations that may require a flashlight. The only other flashlight that I own is a 2-D maglite (led) that I purchased last year. I would like something that is more compact and runs on AA batteries.
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
__X_I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $25.
____Less than $50.
____Less than $100.
____Less than $150.
____Less than $300.
____I have no limit.
____I’m flexible, tell me what you gotJ.
__X_Other, please specify ___<$60__
3) Format:
__X_I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
__X__Keychain size.
__X__Every day carry small (2-4 inches).
___Every day carry medium (4-7 inches).
___Holster carry.
____Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
____N/A
5) Emitter/Light source:
__X_LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__X_I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
X-AA I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
__X__I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
__X_I want to navigate a dark room or read a map (0-10 lumens).
__X_I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
__X_Less than 1 yard/meter (reading, other close work)
__X_Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
__X_30-50 yards/meters (I have a big backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
__X_90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
__X_Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____I don't care.
__X_I don’t know.
____A simple on-off with only one output level is fine for me.
__X_I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
___I want multiple light levels. (Some lights have 5-16 light levels.)
__X__I want a programmable light.
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
___X_Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
___I don’t care.
____I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
I've answered the questions as well as I can. I should mention that I'm looking for at least 2 lights; one for my key-chain and another, bigger, single cell light for other things. Some key-chain lights I've been thinking about are the Fenix E01, & Olight i2/i3. For the bigger light I'd prefer the smaller size of a single cell AA light, but would also consider a single cell CR123 light as I have access to both battery types at work. Some lights I've been considering for this are the JETBeam BA10/ BC10, Klarus P1A/P1C and Quark AA Tactical. I don't need strobe or SOS, just a fairly simple 2 or 3 mode UI. Sorry for being long winded, but I'd appreciate the feedback and any other suggestions or comments. Thanks!
____Less than $25.
____Less than $50.
____Less than $100.
____Less than $150.
____Less than $300.
3) Format:
__X__Keychain size.
___Holster carry.
____I don’t care.
____I don’t know.
____N/A
____I don't know.
6) Manufacturer:
____I don't care.
____I don’t know.
____I don't care.
__X_I don’t know.
____I don’t care.
____I don’t know.
___I don’t care.
____I don’t know.
____Holster
