Any changes coming to user interfaces?
EDcLED
Any ideas on new and interesting microprosser controlled user interfaces? MY thoughts are a pressure sensitive touch contol whereby different pressures set the output at different levels. Say a low light is prefered, then pressing lightly cause the microprosor to change level accordingly and at the instant the pressure is released that amout of output is locked in. A tap would turn the light off. should there be a bump in the night situation instant maximum would be acheived probably merely from the excitment of the situation. It would be an infinitely variable controll determined by the pressure on the switch at the instant reversal of pressure was detected, that is at the instant the finger began to release pressure. Just wondering if there are any technicians out there that have oppinions as to the feasability of the idea.
