any cree shakelights around
qip
u.s
from what i gather the nightstar is the best of the shakelights but uses the 5 or 10mm led , anyone ever mod one to cree
That wouldn't work well... most of those shakelights are driven with far less than 20mA. XR-E's need about 20-25mA to light up... and their brightness is rated when driven at 350mA. That would give a few seconds of light per 10 minute shaking...
You could mod the LED with a Nichia DS or GS. They're 5mm LEDs, and are reasonably efficient with a few mA's
Unless you're superman shaking a huge light, then no it wont happen. a little capacitor or battery won't provide enough power to drive a CREE.
I remember someone around here that has this signature:
"A shakelight ?? :twak: "
You can mod a shakelight with cree.
If you want 5 seconds runtime.
guess not then :shrug:
stuff a larger capacitor in there :devil:
I'm not sure how much more power you get from a good crank light but a crank light might work. Freeplay had/has a crank light that powered a Luxeon LED.
I think it is a legit question.
Can't a cree be driven at much less than maximum? Is it still efficient at lower currents?
HDS/Novatac/Ra can drive the emitter at low levels. Does the efficiency change as a function of current?
Does die size limit the minimum current? Aren't these cutting edge emitters more efficient in general than older emitters?
From what I've heard, yes it can and is more efficient. The problem is how low is "low":
It sure can. Perhaps you've tried taking an ordinary LED holding one leg with one hand and in the other hand holding a 9v battery. Now touch the free leg of the LED with the free terminal on the battery it'll glow (observe correct polarity) - how depending on how moisture your hands are. How that? Well, as said a LED is more efficient at lower levels and it doesn't have a minimum amount of current - as long as voltage is high enough that a very tiny amount of current can flow it convert amounts of the energy to light.
Do it with a Cree and it'll glow even a bit more than the average standard 5 mm white LED.
How it compares to a high performance like Nichia as low levels I don't know - haven't tried. But I'll almost bet the Cree will be a little brighter in a :twak: light than the LED it got from the factory (they're most likely using the cheapest junk they can get).
BTW. The limiting factor of those :green: lights is the capacitor. A Cree can not draw any significant power from it than the 5 mm LED. They're usually direct drive and if they're supplying too much they'll blow the LED. Those very high capacity tiny "super" capacitors can only deliver some mA and probably not much more even when totally short circuited.
Replace the capacitor with a more powerfull one and you'll instantly ruin the LED if not making a limiting factor such as a constant current diode (or FET coupled as such).
