tvodrd
*Flashaholic* ,
I was playin' with the overdrive out in the desert on Thanksgiving and the lamp exploded- audible "pop" accompanied by instant darkness.
I hadn't gotten around to calling Peak Beam when Short Arc emailed me with what was supposed to be a very good deal on a lamp replacement kit. I bought it for ~$245.
Today I proceeded to install it. Loong needle nose pliers extracted the lamp's base from its socket behind the reflector, cleaned reflector with supplied solution/cloth after a major compressed air blowout. (I opened it out in the desert to dump the broken glass so it wouldn't be rattleing around inside the reflector on the ride home.) The reflector took some shrapnel damage which I hereby describe as "character marks!"
Anyway, I put the supplied, safety glasses on and removed the cap on the lamp's clear plastic packaging tube. I grasped it by the front metal piece and pulled it out, at which point, the lamp dropped off the metal piece I was holding and hit the floor between my feet!
At least no "pop/bang" and need to tweezer glass from my whatevers. I just abt s...nevermind.
I pushed the lamp into its rear socket and clipped the front connection on, installed the replacement O-ring and stopped to think. Did I lose a spring, or was one missing (I couldn't find one anywhere on the floor) between the "shock absorber" piece that remained in my hand when the lamp dropped off of it or??? It seems to me there should be a spring in the front end of the lamp assembly. For giggles, I put the window back on and with the "centering adjuster" covering screws removed, took it to the garage and lit it off. The focusing motor couldn't and sounded to be in pain. It's like I didn't insert the rear of the lamp deeply enough into its socket. I removed the window and attempted to press it in deeper with no joy!
Anybody been there/done that and can offer some insights?
Larry
![Rant :rant: :rant:](/styles/default/xenforo/smilies/3/rant.gif)
Larry
