jesusthepirate
- Joined
- Sep 23, 2008
- Messages
- 6
I've used the wiring diagram that netkidz posted a while back in order to use a pair of standard 1400mA AMC7135 boards from DX in parallel, and I'm having a little trouble. I've been trying to run a Cree XR-E P4, a Cree XR-E Q5, and an SSC P7 (all separately of course) at ~3 amps. The XR-E's are TEC cooled. I haven't measured vF on the SSC, but for the Cree's it's about 4.5vF @ 3.2A, and I just can't do it on 4x NIMH AA (Energizer 2500mAh) or generic 3000mAh Sub-C... I can get about 2.4A going through the P7 and around 1.5A through the Cree LEDs with that setup. Thing is, if I up the cell count to 5 I have no problem, 3.0-3.3Amps works fine through any of the mentioned LEDs.
Voltage sag with -4- cells is not bad, under load they are maintaining 5.5v pretty easily, so there's a whole 1.0 volt between vBattery and vF... I just don't see what's going wrong. In my frustration I've wired up a second pair of those AMC7135 boards, removed the reverse polarity protection diodes (to no real effect of course), etc...
Sorry for the wordy post and thanks for any help!
