Arc LS & Travel
Status
Not open for further replies.
Foss
I've traveled 4 continents with the Arc LSP and it's a great light. Small enough to bring everwhere and a great battery life.
My only complaint is the tail switch. The rubber boot is pretty worn on mine due to use. It's also much softer to turn on and off then when it was new. (sometimes turns on and off in my pocket) Does anyone know if the twist caps are still available for the LS or any mods. to the existing light switch?
Check out the post from JonSydneyB in the dealers section. He may be selling some shortly!
You can pick up a new Kroll switch at the sandwich shoppe at http://www.anlighten.com/shop/default.php in the accessories section. While you're at it, you might want to try one of gadget_lover's hi/lo switches (in custom & mod B/S/T). If you liked your LS before, you'll really like it after you have a high and a low mode!
If you think the switch is broken, I'm sure Arc will take care of it for you.
Status
