<font size="2" face="Verdana, Arial">I believe I speak for Mr. P. Gransee when I say;Originally posted by aznduece:
This has happeneed to me too.. I have a Arc AAA LE. What should I do?
<font size="2" face="Verdana, Arial">My 3.1 LE is also doing this. I tried different batteries and cleaned the contacts but no change. It is also very dim and blue. I have pulled the foam off the head, and it does indeed appear to be a 3.1Originally posted by Saaby:
I have an Arc AAA and occasionally under freak circumstances it doesn't turn on. Usually this is when I have been using it, and turn it off, and try to turn it back on. TO fix it I have to take the head almost all the way off and then put it back on...is it just the battery being off center? This is ver 3.1 with the roll crimp if that helps![]()
Note: It's not by any means a flicker, once it's on it stays on...it's just getting it on in the first place.
<font size="2" face="Verdana, Arial">i noticed on my cpf that the epoxy had oozed out around the edge.Originally posted by Gransee:
Hmm. The first batch of roll crimps could of used more "meat" to the lip. Later versions have a larger crimp to grab the PCB with.
Peter
Originally posted by Unforgiven:
<font size="2" face="Verdana, Arial">The home made crimp appeared to fix the intermittent not working problem....all is wellMy 3.1 LE is also doing this. I tried different batteries and cleaned the contacts but no change. It is also very dim and blue. I have pulled the foam off the head, and it does indeed appear to be a 3.1![]()
<font size="2" face="Verdana, Arial">After I used a screwdriver I used the beveled edge of a small socket, 1/4 drive..... made a nice tight crimp.Originally posted by Saaby:
Cue Kyra:
UT-OH!!
I was headed off to bed and then Mr.Arc acted up again so I brought my computer out of standby to post, ya know keeping CPF informed and all...
Yup, it improved A LOT when I did the roll crimp but I guess it needs some more work, I'll use a bigger screw driver this timeoh well, I have faith in the little bugger, so no worries but
did I just use a derogative word to desceibe my Arc? Well, it will never happen again, and please don't quote this as I will likely edit that out tomorrow...![]()
