Arc4+ 16 Levels: Estimated Run Times & Brightness
Status
Not open for further replies.
coyote
eastern oregon
folks,
i've taken some actual Arc4+ run times that have been posted on CPF, statements by Peter @ Arc, best guessimates by flashaholics and basic deduction to come up with this chart. i'm sure it can use corrections and i invite everyone to put in their two-cents...
Arc4+ 16 Power Levels: Estimated Run Times & Brightness
Level 1 - 15 Min @ 600 Lux followed by 1 ½ hr at 500 Lux - High Level (Fixed)
Level 2 - 2 hours @ 500 Lux
Level 3 - 3 hours @ 400 Lux
Level 4 - 4 hours @ 300 Lux
Level 5 - 6 hours @ 225 Lux
Level 6 - 8 hours @ 175 Lux
Level 7 - 12 hours @ 125 Lux - Adjustable Level
Level 8 - 16 hours @ 90 Lux
Level 9 - 1 day @ 70 Lux
Level 10 - 1 ½ days @ 50 lux
Level 11 - 2 days @ 40 Lux
Level 12 - 3 days @ 30 Lux
Level 13 - 4 days @ 20 Lux
Level 14 - 6 days @ 15 Lux
Level 15 - 8 days @ 10 Lux
Level 16 - 10+ days @ 5 Lux - Low Level (Fixed)
Thank you for that EXCELLENT post! It's possible that some of the details will be "tuned up" by our members, but this is an excellent start!
Thank you for the info. I posted this question several weeks ago but got no replies. This is the first list I have seen that covers all 16 levels. Again Thanks.
that is very useful. thanks coyote /ubbthreads/images/graemlins/smile.gif
Re: Arc4+ 16 Levels: Estimated Run Times & Brightn
Very useful info !
Something like this should even be added to the manual, I think.
This should really get into the Faq, because I think thats very usefull to every Arc4 owner. Perhaps you could draw a nice graph from this measurements?
thanks everyone for the kind words.
T-I-N: nope, these are in no way confirmed. in fact TIN, i took some of the info from your recent LS run-time graph (and many thanks for doing it and posting it!!!).
remember, these numbers are only my best estimates based on found info. i'd hope that someday these numbers can be confirmed by one of you pros who have the testing gear and electronic knowledge.
as for me making a graph, i wouldn't know how. anybody else want to jump in and do one, please feel free. this list is now the property of everyone at CPF so anyone can use it as they wish.
I don't think you're going to see an official run time chart anytime soon. I have several 4+s, and the current draw varies tremendously between them. I don't see how an accurate run time chart can be created with these variables present. The 4+'s calibrated brightness is often not very kind to your batteries. /ubbthreads/images/graemlins/icon23.gif
Peter
i think it would be possible to have a ballpark set of runtimes for both the standard and premium arc4s, based on the acceptable current draw standards for both though.
Unless there's serious variation between samples I think this would work. At least by class (4 and 4+). All levels within plus or minus ten percent, etc.
What is the runtime of locator, level 16? Probably measured in years LOL.
Cheers!
[ QUOTE ]
[/ QUOTE ]
Which are...? /ubbthreads/images/graemlins/icon3.gif
Peter
well, i was hoping peter gransee himself would chime in since he's aware of those figures /ubbthreads/images/graemlins/smile.gif
/ubbthreads/images/graemlins/popcorn.gif
Peter
pass it around /ubbthreads/images/graemlins/smile.gif
In the FAQ, Arc stated the runtime would vary by as much as 50% and I believe this is true.
I've actually estimated the runtime of all levels based on my runtime results, but I've not posted the result since it cannot be accurate. Now I just uploaded my result to my Arc4 page since the attempt to estimate the runtime has started in any way and you guys probably want data as much as possible.
I agree that's great if Peter Gransee gives us the runtime result of all levels with his average Arc4/Arc4+ /ubbthreads/images/graemlins/smile.gif
[ QUOTE ]
[/ QUOTE ]
That's what I was fearful of and that's why I asked. No where do I ever mention Lux/CP/Lumens as a unit of measurement in my testing. Those numbers I posted mean nothing other than a comparative way to measure the difference in light output from each unit, during each test.
TIN-
that's a reasonable question.
i offer you this in answer to your comment on Lux/CP/Lumens:
the only reason i chose to use LUX in the above list was because peter himself used it in his "Arc4 Advanced Instructions" CPF posting
(http://www.candlepowerforums.com/ub...=436125&page=3&view=collapsed&sb=5&o=&fpart=1)
where he said: "...Output: (600 lux at 1 meter for 15 minutes, 300 lux at 1 meter for 2 hours)..."
seeing as we don't have access to more exacting specs (ie: Lumens) and all i was hoping for at this point was a comparative list, i took that 600 Lux as my highest possible brightness and then figured the lower levels as a portion of that.
to determine those lower levels i again referred to info on that same page where peter stated: "...Every two settings
brighter will halve the battery life and every two settings dimmer will double the battery life.... The efficiency of the LED increases when the LED is run at lower power settings. The increase in efficiency can exceed 40% by 6 settings below the maximum setting."
i then used his suggested ratios, along with CPFer info, including your chart where we can see how quickly the brightness drops off when used in Level 1 (i didn't use your output numbers, only the way the brightness changed and the ratios between the two different levels of the Arc4+ you tested), to come up with the above estimates.
while it is my hope that we will someday have a real run-time chart to view, i think this existing list will for now at least help us in deciding how to best use our Arc4+ flashlights.
kj-
i just took a quick look at your Arc4 webpage. nice work on all your estimates.
i need to spend some time reviewing them and hopefully will find info useful in updating my list. i would be happy to have any direct input you'd like to offer.
-coyote
Status
