I have about 6 Eneloops that are in constant use in my GPS...
...One set, that I labelled #3, is acting strange. For quite a while, if any of them were charged and I put them in the MH-C9000, within a couple of minutes at most, I would get an indication that they were charged. The rest still do this, but #3 has started showing "HIGH" on the readout of the MH-C9000.
Does this mean #3 are ready to be recycled? Or should I ignore it? Or what?
It probably means that set #3 is ready to move on into its "Semi-Retirement" stage (remotes, clocks, thermometers, etc...).
Please read:
Interpreting Maha MH-C9000 Impedance Check Voltage
- What's the ICV of set #3 in the DISCHARGED / cool (room-temperature) stage?
- What CHARGE RATE do you use?
- Are the set #3 cells HOT (over 120°F) at the end of their Charge stage?
BTW, how many (estimated) CYCLEs do you have on these cells? (i.e. Charged DAILY, or every 3rd day, 5 days/week, 50 weeks/year, 1,2,3,? years.)
Try a discharge/charge on the C9000 and see what happens.
If I had time, I'd do
Discharge
Charge
Discharge
Breakin
Record readings at each point...
I wouldn't bother with all that effort ('
Been There, Done That!'). Once a cell reaches the HIGH stage, it's pretty much already moved on into "Semi-Retirement". Now, *IF* the user had been MONITORING ICV along with CAPACITY, it would be interesting to see if the ICV proportionately increased as the CAPACITY decreased. :thinking:
...To measure resistance, put in a cell, hit the enter button until it starts charging. The first voltage reading you get will be the cell's internal resistance...
Not true. The first voltage reading is the C9000's IMPEDANCE CHECK VOLTAGE (
Measuring Maha MH-C9000 Impedance Check Voltage), measured in VOLTS, which is somewhat PROPORTIONAL to the cell's Internal Resistance. Internal Resistance is measured in OHMS via a different method (2 are listed in my Sig Line LINKs).
...Consensus seems to be that if a NiMH ever says "high" you need to say "bye."
It depends. Many of us get *MANY* more years of service out of HIGH (and even MODE!) cells in low current devices.
...How many cells does the GPS hold at one time? If it's only 2, there's probably not much chance of getting a reverse charge.
It all depends on the 'Voltage Cutoff Point' of the device. Wherever there is more than ONE cell in SERIES in a circuit, the POTENTIAL for a reverse charge exists.
Also, the published numbers of "1000 cycles" or "1500 cycles" for cell lifetime do not line up exactly with real-world results. If you are putting cells through full charge/discharge cycles (as you probably would with daily use of a GPS) then the cells may wear out within maybe 200 charges or so (just as a rough guess). So if you have had cells in daily rotation for, say, a year or two, you might find they are reaching their natural end of life.
Do you really believe that, even if one is REGULARLY USING and PROPERLY maintaining the cells, they may wear out after only ~200 cycles?
I always refer to the example of "
Charge a cell WEEKLY for 10 years and that's 520 cycles" and probably the end of the life of the cell TIME-WISE. Thus, I always believed that folks who recharge DAILY (i.e. police, fire, EMT, etc...) *WOULD* get 1000-1500 cycles.
__________________________________________________
KD5XB,
Just out of curiosity:
- Are you an Amateur Radio Operator?
*AND*
- Is the truck you're referring to an 18-wheeler?
*AND*
- Per your avatar, are you also an F-18 pilot?
