Hi folks,
I'm still searching for a cheap power supply solution and have another question.
I have an old netgear firewall/router that uses a power adapter that plugs into the wall.. You know, those little square black boxes that plug directly into a wall socket. The adapter says 12 vdc and 1 amp on it..
I bought some 10 watt power led's on ebay that take 9 to 12 volts and use a max of 1050 mA current..
So would this little power adapter work to light up a single led chip? I guess what I am wondering is if that 1 amp is regulated or would the power adapter blow an internal fuse or something if it went over 1 amp..
Anyone ever try one of these?
