are sylvania high performance light bulbs brighter than OEM ?
picard
are sylvania high performance light bulbs brighter than OEM ? I am referring to halogen bulbs that look like HID
If you mean bulbs with blue tint, or blue/white or advertised as "hyper-white" or "crystal vision" or anything like that, NO.
The blue filter takes out light. Coloring it blue may ape the appearance of some HID lamps (though the only HID headlights I own are a pretty "white" 4,200K color temp), but it is not brighter and it makes it more difficult for your eyes to focus. You many want to read this article:
http://www.danielsternlighting.com/tech/lights/light_color/light_color.html
Depending on the type of bulb you have, your best bet may be Philips Xtreme Vision or Xtreme Power or the Osram Night Breaker.
are sylvania high performance light bulbs brighter than OEM?
No. The Sylvania Silver Star/Ultra bulbs you are probably asking about have a short lifespan and put out less light than an OEM regular bulb. The Sylvania Silver Star ZxE bulbs you might be thinking about are an extreme case: much less light and a very short life.
Halogen bulbs aren't supposed to look like HID. There's no point trying to force the issue; halogen headlamps will never really look like HIDs, and even a slight appearance shift in that direction substantially reduces bulb output and lifespan and headlight performance. The best-performing bulbs in Sylvania's line are the XtraVisions, but you can do better in other lines (Philips Xtreme Vision/Xtreme Power, GE Night Hawk Platinum).
"But why is this so?" Stern on Light Color.
"But why does that matter?" I dunno about you, but I like all my light. Speaking of CCT, the moon was considered greenish until we started seeing it next to sodium-vapor lamps. Then it was blue.
