I have just put a battery in the freezer. I will see what is gonna happend.
After 2 hours in the freezer, burst on high ( head tightened) for about a second. The other modes are working well.
Battery voltage 4.16v. Cannot check the capacity though, evidently.
Guess these XP-L LEDs need a lot of power to drive them all the way.
I did a little research on 18650's & I found that Panasonic/Sanyo have something like over 100 patents in battery tech & a lot of them are to do with Li-Ion's.I also found that nearly all of the companies that don't produce their own batteries
by them in bulk from Panasonic/Sanyo & put a wrap on them with their own name & logo.So i went straight for the Panasonic cells & they're the best performing batteries I own.In fact I'm ordering another couple tomorrow.
These batteries(2) are working the same 12 hours later...short burst on high. A chance I tried crap ones. I will try a capacity test. Li-ion doesn't like freezing....?
Did you let them warm up the 12 hours or were they in the freezer? The working temperature of my cells is listed to reach down to -20 °C. Maybe the battery chemistry simply feezes below that.
I let them warm up 12 hours. The low modes are working great, just the high mode that cannot keep it high. Just a burst...for about an half of a second. Interesting test.
Mine started working again normally when I recharged the battery. I had been using in it in really cold so the voltage was below 3.8 V. Are you sure it's not the protection circuit? What happens if you recharge the batteries?
Nothing to do with these cells. After a refresh C>D>C the capacity is still at 1800mah, but same problem. A chance that I did not do it with a brand new set. Something happened inside the cell...
