Ninja
That hard twist on/off is due to the pressure sensitive switch (located on the side of the pc) not making contact. The fix is to remove the top bar & adding solder to the 2 contacts underneath; put a drop of solder on the top of the bar & replace it.
The bar slips off the 2 plastic poles after squeezing the mushroomed tops with plyers or tweezers. When finished soldering, put it on & mushroom the top again to hold it on.
