The Coach
Anybody try the new AW IMR 18350 in their Tri-EDC yet? I have a couple on the way.
whats the better battery to use for macs sst-50 the ultrafire or the aw imr 18350s. i know that they are all going to be able to use the 18350.
also whats a good charger for them?
I am using the Ultrafires with my Tri EDC and have no issues at all. I run the heck out of it then throw in on the hobby charger I have using magnets and the alligator clips. Never tested run times and I just charge it when I think I have used a bunch. I carry a spare in my pocket (nothing metal along with it) just in case but have yet to need it. Med setting is quite bright and does the job and high just seems to be for fun.
With these AM 18350 Batteries do they charge the same as the Ultrafires? I dont have a reason to switch as of yet and the Ultrafires have been used constantly since the first run Tri EDC came out. The same 2 batteries have been in rotation in my pocket and each has seen several charges.
Well I havent had an issue. I charge from a Hobby charger for Lipos at .50 and it peaks then shuts off at 4.07v. So far so good but if there is something dangerous I am not aware from please educate me. Its nothing for me to buy some better batteries if thats what I should do.
Thanks
so in terms of just sheer safety i should go with the imrs right?
yeah im just going for safety... maybe after i familiarize my self better with theses better ill go for power... thanks though
The IMR and LiCo cells operate within the same voltage range so its not "power" that is different, it's the runtime (ie. capacity) with the IMR having slightly lower runtime.
okay that makes sense... thanks for the clarification.
what charger do you recomend for an IMR battery?
