BadA$$ Maglite
Ginseng
Ok, it ain't no kilo-lumen MR-16 mod and it's not powered by 2 pounds of 1/2D nicad battlebot cells but it's pretty gnarly in its own right.
Now that my humble Mag 3C has been force-fed four SureFire 3-Volt lithium batteries, one Energizer AA Lithium and a secret ??? lumen bulb, I wanted it to be capable of not only throwing a killer spot, but also generate a useful flood. And since I have a professed love for holographic diffusion filters, I picked one up for this torch. I just couldn't bear to have such a nice torch suffer the indignity of the "Mag Hole". Note: This bulb necessitated the use of a reamed out Carley 1940 aluminum reflector as the stock polycarbonate unit would not survive the heat. For intermittent use, though, the stock reflector is just fine.
The no-nonsense flip up, cam-lock filter is SureFire's FM24 Beamshaper. It is designed for 2.5" bezels like the SF M6 so it is exactly 1/4" too large in diameter for the unmodified Mag bezel. To make up the difference, I wound on several layers of 20-mil, high temperature pipe sealant tape around the front bezel ring (the part Mag refers to as the "face cap"). I then sealed it up with a high temperature silicone, fiberglass-reinforced foil tape. The foil tape provides toughness and abrasion resistance. The tape band is 15-mm wide, exactly covering the front bezel ring. Since it doesn't cover the seam between the bezel ring and the head, the bezel can be unscrewed to access the lens and reflector. In fact, you can switch bezels between lights with ease. I can swap the FM24'd bezel from my BadA$$ 3C to a 2C packed with 3x123 and a C717 or KPR112 to my ab-made 5W 2D Mag.
Ok, enough talking. Here's the beamshotz. As you can see, the diffusion filter provides an unbelievably homogeneous field of flood light. No naked reflector can match this uniformity. I have to say though, even without the diffusion filter, the secondary spill is very bright and very useful. The shaped beam is just another class of gorgeous though. I have some Carley 808 bulbs (smooth glass and frosted) and texturized and smooth aluminum vacuum coated reflectors coming in the near future and I hope to be able to definitively quantify the relative effects of bulb frosting and reflector texturizing. I want to know how each process affects the spot tightness and overall diffusion to the wide spill.
Left: Beamshaper out, tightest spot.
Right: Beamshaper in, uniform flood.
I took it out tonight for some shooting around and the throw is absolutely stunning. Here are some comparative beamshotz that you might find interesting.
Picture 1, spot mode: Left, 2C(KPR112 + 3x123) Right, 3C(Xbulb + 4x123+AA)
The mystery bulb versus the "bang for the buck" champion. A nice bump in output I'd say. The spill light is just ferocious but doesn't show that well due to the exposure.
Picture 2, spot mode: Left, 2D(5W LS + 6xAA) Right, 3C(Xbulb + 4x123+AA)
My hottest incandescent versus my hottest LED-based light. Color difference notwithstanding, the difference between 500 lumens and 150 lumens is clearly visible. Even moreso in person. The Luxeon does have two positive aspects though, great color (V3U) and a perfectly round spot with no artifacts in tight beam mode.
Picture 3, spot mode: Left, SF9P(P91HOLA + 3x123) Right, 3C(Xbulb + 4x123+AA)
My hottest incandescent versus the former hottest incandescent. Carley 809 not included. Can you see the difference between 500 and 200 lumens? After seeing this, my 9P goes into retirement until the SF KL5 LED head becomes available. The smaller, less efficient but texturized reflector of the P91 results in a much smoother but less concentrated hotspot.
Picture 4, spot mode: Left, 2C(stock bulb + 2xC) Right, 3C(Xbulb + 4x123+AA)
Just for chuckles. Believe me, it was not this close to the naked eye.
Wilkey
restored 12/21/06
Well golly Wilkey, do we have to pull it out of you, or can we just be patient for you to tell us what this xbulb is? How much current are you pushing through there?
Yes, you are bad. I'm impressed. A nice job and a graphic, useful review, too. And the beamshaper with modded adapter is also bada$$. But . . . just a few facts left out . . . ? /ubbthreads/images/graemlins/smile.gif
Paul
Paul,
The bulb is rated for 9.6V, 1.93A, 3300K color, 534 Lu, T2.25 size. It's being pushed to 10V is my guess. It is actually not a secret. I've mentioned it a few times in discussions in other threads. It's the WelchAllyn 01318. I got it in stiff pin form and plugged it into a Carley 912 adaptor. I don't run it for more than 15 seconds at a time so I've had no problem with the reflector melting. The bulb had a long glass tail that necessitated a little drilling out with a Dremel and a small tool steel carving bit. Don't try it with a regular drill, 3,000 RPM and too much torque. 10,000 RPM makes a very neat hole without stressing the plastic potting. This was to make a small hole between the pin sockets to accommodate the glass tail. So far so good.
This is the only bulb I've had in a Mag that I am impressed with, aside from the amazing value KPR112.
Wilkey
Well, it can't be the W3U I sold you, it would've fried like in 5 seconds. Hmmm...wonder what the secret bulb is.
Nice work BTW. /ubbthreads/images/graemlins/thumbsup.gif
Oh nevermind...just missed your post by 240 second
Wilkey,
Oh yes, the renowned WA 01318. I have indeed heard of that. I remember your great hope for it. I'm delighted that it meets your expectations. /ubbthreads/images/graemlins/thumbsup.gif
Paul
P.S. The 912 adapters came in? . . . or are you using one from a different batch?
P.P.S. I like your new avatar. I know what this one is!
Paul,
The 01318 is probably one of the brightest bulbs that can be run off non-rechargeables. My guess is the runtime is on the order of 20-30 minutes or so but I really have only used it intermittently.
Carley had sent me one 912 with the main order and I've been playing with that one. I'm still waiting on the 5 that Patty sent out last Friday. Hopefully today. They couldn't tell me much more than the base is filled with "plastic". That much is obvious, since it drills out in little stretchy bits rather than a fine dust (like ceramic) or hard chips.
The last avatar was an overripe Chinese bitter melon that had exploded, casting its bright red seed capsules.
Kirk,
I've got special plans for the W3U you sent me. Thanks again for making this available.
Wilkey
