DieselDave
Super Moderator,
I love it. Batteries are alkaline in the shots. Will get some lithiums on the way home from work.
Badboy 500 Pics
Badboy 500 Pics
<font size="2" face="Verdana, Arial">nice photo shots, Dave-thanks!Originally posted by DieselDave:
[QB][/QB]
<font size="2" face="Verdana, Arial">I had a feeling that was right but thought I had read somewhere that lithium's worked best. My perception that it was a little brighter was probably my mind trying to justify the $7.50 worth of batteries inside the tube.Originally posted by geepondy:
Dave,
The advantage of the regulated light is not having to use lithiums as the regulator is a constant current design and not voltage regulated. I've fooled around some and possibly lithium's may be just a tad brighter then alkalines and rechargeables just a tad less so but it just could be me and if there are any differences they are very minor and theoretically there should be none.
<font size="2" face="Verdana, Arial">My BB500 is worth more to me than what it is really worth. It's a keeper.Originally posted by Icebreak:
DiesalDave-
How much is your BadBoy 500 worth?
How much would you sell it for?
<font size="2" face="Verdana, Arial">After you insert the module down the tube which took a little playing with to get it past the final set of threads then you drop in the C-Clamp. You look down the tube and make sure the C-Clamp is lying partly on its side so that when you insert the batteries and apply VERY light pressure the C-Clamp is pressed flat against the bottom of the module. I repeat, it takes VERY light pressure. Once the C-Clamp is installed it would be very difficult to remove without destroying the module. Perhaps...You could use a dental tool to unseat the C-clamp but you would have to be very carefull.Originally posted by geepondy:
Dave,
Could you tell how you got the c clamp on? I looked it over and wondered how easily the sandwich would drop down the tube if installed and decided against it for now but if you could relate your experience in more detailed that would be nice.
<font size="2" face="Verdana, Arial">By "total power" I think that you really mean energy. Energy=powerXtime. For low power drain, an eveready lithium AA [L91] and an eveready alkaline Energizer AA [E91] can deliver about the same total energy. As rate of discharge is increased [power] the amount of energy that can be delivered by the E91 falls much more than the L91. At the power requirement of the BB500, about 2W total or 1W/cell, the L91 can deliver 3 times the energy of the E91 before the cells no longer can provide full power to the BB. Yes, at high rates and low temps, the L91 does even better relative to the E91. It is very informative to visit the Eveready website and download the L91 applications manual. It has some good comparison data for the L91 and E91 under constant power discharge.Originally posted by BuddTX:
The way I understand Lithium batteries (and someone with more knowledge PLEASE correct me!) is that they do not necessarly give more TOTAL power, but give more FULL power to high drain devices, and are much better in very cold temp.
Think of a large syringe and a container with a small opening, both filled with the same amount of water, the water can be poured out of the container only so fast, but the water in the syringe can be forced out, but the total amount of water was the same.
Not a perfect example, but semi ok, anyway.
<font size="2" face="Verdana, Arial">I would suggest the Kroll Cap, and two or three Mineral Crystals. They are too cheap not to have a replacement standing by.Originally posted by FNG:
What accessories would I need to get besides the Madmax?
<font size="2" face="Verdana, Arial">Originally posted by DieselDave:
I mis-spoke in my earlier statements. I used the new brass retainer ring that was supplied with the module. I threw the silver C-clamp away. I used the generic term C-clamp. Here is a picture of the retainer ring installed. Dat2Zip feel free to use this photo or other images on your site for instructions or anything else you need. I love my BB500, great job, Thanks, David
