Re: Basic battery question
Thanks for all the replies, I'm definitely learning!
The only thing I have ordered is the voltage regulator I mentioned earlier (which won't go to waste, I have 12V SLA batteries I'm going to step down). I'm just trying to decide on Li-Po batteries for portability (trying to keep the batteries around a pound or less in weight).
I goofed in my original post. I need 7.4 volts as someone pointed out in battery arrangements. I have two applications in mind.
The first is an external battery pack for my digital SLR camera for extended time lapse sequences which requires 7.4 volts and should not draw more than 1.5 A.
The second is a power source for a bicycle headlight I have yet to buy/build. I've done a little browsing around and from what I've seen it looks like many bike lights tend to use higher voltage.
My reasoning for sharing the same battery pack is because I will be riding the bicycle and hiking to many of the spots where I'll be doing the time lapse photography. :twothumbs
I've been looking at these battery packs:
Polymer Li-Ion Module: 7.4V 10 Ah (74 Wh) Prewired with PCB
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=2333
Polymer Li-Ion Battery: 7.4V 10 Ah (74 Wh, 9A rate) with Fuel Gauge
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=4488
Li-ion 18650 Battery: 14.8V 4400mAh (65.12Wh) Battery Pack with PCB
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=3600
Mr Happy suggested rearranging cells for intended application. Would it be easier/cheaper to buy single cells for that purpose instead of battery packs? Also, any suggestions for battery retailers is welcome. I have never purchased cells/packs before.
Again, thanks all! lovecpf
