How many volts and ampere a battery need to be able ti drive 4 cree q5 leds at maximum capacity??
How can I preview how burn time I 'll have?
I am unable to understand how volt influence the luminosity
is a 12 volts 4000 mAh battery better than a 3,7 volts battery 4000 mAh??
If I remember correctly V= I x R so se if R stay the same I assume that the first one (12 V) could give more current? ( more burning time?)
Is it right?
Can someone explain me how it works or point mein the right direction?
Thank you
Andrea
Is it right?
Thank you
Andrea
