In a 2 or 3 D cell maglite with a Terralux TLE-6EXB LED drop in, what would be the performance results from switching from an alkaline cell to a 10000 mAh NIMH D cell battery. I understand that the voltage would be slightly lower. This bulb is for 2 or 3 cell flashlight and it is dimmer with 2 cells, brighter with 3 cells. The voltage with the NIMH would be between 2 cell and 3 cell alkaline batteries. The logical conclusion would be dimmer than 3 alkaline cells but brighter than 2. Is that correct? If I used it in a 2 cell flashlight and voltage was less than 3 volts, would this bulb still perform? How would run time be affected. If the bulb would run 5 hours on alkaline cells, how long would the above cells run?
Thanks for any help.
