Battery question!
1911operator
Im powering a small led using my cellphone battery for fun. and I have this question to ask.
Would using 4 AA batteries last atleast twice as long as my phone battery?
Phone battery: 3.7V 2100mah
4X AA: 5.5V (each 1900MAH) so to be safe 7500mah
Could I theoretically connect these 4 batteries to my cellphone and charge the phone twice? and also power the light twice as long?
Nope - if you connect the AA's in series, you have the same mah at a higher voltage, so in your case, 4.8v or 6v depending on chemistry, at 1900 mah. That is a little more energy than the cell phone (9.1 - 11.4wh versus 7.8wh) but not double.
Volts x Amps = Watts 1.5x1900x4 = 11.4wh vs 3.7x2100=7.8wh There are boxes that allow you to use two or more AA cells to power/charge a USB device. In theory you could charge your phone about 1.4x via 4 AAs of that spec (adjust if you are talking Eneloops as they are only 1.2v each not 1.5, and there will be some loss converting to 5v USB current). Same for powering a light - its watt hours that give the best rough estimate of capacity.
ah yea u guys are right, they are in series. sorry im a noob with this. :/ so what could I do to charge the cellphone that would allow me to get the most power and effiency?
yea im looking for a project. I just tried that and the booster got really hot, i could put my finger on it for about 2 seconds and it burns. looks like its not liking that. is there another booster that would be better?
