Battery Runtime Calculation
Status
Not open for further replies.
Goldigger
London UK
Hi,
Apologies if i have posted in the wrong place.
I have put together 3 Seoul P7's wired in series driven by a Konlux 2800 driver + BOOM P7-S reflectors. I ran these of a 12volts mains adaptor with the p7's attached to a heat sink.
I think the Konlux 2800 driver drops 2 volts, so i get 10volts shared by the 3 leds 3.3 volts at 2800mah/8400mah? I know the leds require 3.7 - 4.2 volts max each.
They ran fine and didnt get to hot, the driver stays nice and cool. I plan to put this in a suitable host for a dive torch. The part that i am not to sure on is how much runtime i will get from a battery.
My options are a 12volt 4.5ah, 12volt 9ah or a 13.2 volt 4.5ah pack.
Please can somebody advise me how to work this out?
Is the following correct? is this total runtime? how much could i expect it to run at full brightness?
P led = 3 x 3.7V x 2.8A = 31.08W
Battery = 12.0V x 4.5Ah = 54Wh
Let's say efficiency is 95% for the driver.
P in = P led / Eff = 31.08W / 0.95 = 32.7W
Therefore Runtime = Battery / P in = 54Wh / 32.7W = 1.6 hours
Thanks in advance
Status
