While cycling Sanyo 2700 Ni-minhs in my Maha-9000 charger at 1000 Mah charge, and 500 Mah discharge, I noticed that some of the 4 cells felt hot. Using a high end Craftsman Professional multimeter I measured 2 of the cells at 45C. and 47C. This cell temperature exceeded the 40C temperature charging recommendations with which I am familiar.
I seem to remember a recommendation to not exceed 139 degrees Farenheit during charging, but I can not remember the source. These batteries are well below the 139F reccommendation, but over the 40C advice.
These are older cells, and may be developing higher than normal internal resistance.Can someone clarify the temperature issue. I searched the site and coud not find the answer.
