You need to leave base camp to search for help - will one bad cell in 4 keep you from getting lost in the cold dark night? Would you drive through the Sahara desert without first checking your gas guage and spare tire pressure?
You're loaded up on AA's or AAA's or C's or CR123's and all set for a disaster/survival situation. Will you have a way to identify which individual batteries are good/weak/bad? You have a 4AA flashlight with one dead battery. How do you know which battery is the one screwing up your light? How will you maximize battery flashlight usage if you can't match similarly charged cells?
And CR123's - uneven charged batteries can even be dangerous. You have a 2 or 3 cell CR123 light - how do you figure out which battery is weak or dead, causing problems for everyone else? Toss out all 3 because only 1 went bad but you don't know which one it is? Test 50 different combinations of the 6 CR123 cells that you have in your one and only (3 cell) CR123 flashlight?
If you are swapping or scavenging batteries from other sources, isn't it good to test them? Why carry around 50 batteries if only 20 of them are good? Are those packaged lithiums still good after 9 years? What happens if you mix dead and fully charged CR123's?
Another reason to carry a single cell flashlight - it doubles as a battery tester for your other lights? Is there a small tester or way to test batteries when your usual battery tester is not available? Is there a way to McGuyver a battery tester to test individual cells if you are stranded somewhere? Do you guys carry a small tester in your survival pack?
