bb750 and 4C
Lichtgestalt
Germany
I'm planning to build a bb750 in my (already built) 3D-5W-Mod.
Since now I have driven it with 6AAs.
Is it a good idea take 4 C's now ?
How long would the runtime be then?
and would the lifetime of the LED be shortened (extremely)?
Another thing i don't get:
On the wiring-pics (link at shop) there are only 3 different connections described.
I'm not really into electronics but don't you need 4 connections -
2 for the Led an 2 leading to batteries.
thx
On the wiring diagram, J6 is both the LED - and the battery Ground Connection.
6AA with a BB750 is basically DD. The converter board is doing nothing.
The 5W is specified at 700mA. The BB750 will overdrive the Luxeon by a small amount. If you have the Luxeon heat sinked well, you will have no problems or shorten the LED lifetime rating.
Wayne
4C is a great configuration. Any 4 standard cells or two 123s are the ideal battery configurations for the 5W. (6V)
Any two standard cells or a single 123 for a 1W is the prefered configuration. (3V)
[ QUOTE ]
[/ QUOTE ]
Regarding this, Wayne, I have a question. With the MadMax, the max Vin is stated as 3.1V. I have run a MadMax on two lithiums, for a brief time, and after thinking of it, I measured them at 3.6V.
I seem to remember posts of members saying they run the MadMax from lithium cells. Is it dangerous to the BadBoy / MadMax?
Another reason I ask is that, it seems eaier to find 1/3 AA size NiMH, than it is to find ½ AA. In a single cell M³, with MadMax, three 1/3 AA cells may be an option, as well, at 3.6V.
What do you think?
Shankus,
Anytime you push Vin over Vf you are in risk of going Direct Drive. Where the actual DD transition is a couple of tenths of a volt over Vf.
The voltage limit on the IC is around 6V and 3.6V is within the 6V IC voltage range.
I put 3.1 as a specification that I can assure will always work for the 1W Luxeon (not including Amber and Red).
Remember, that most batteries will sag under load. On the 3.6V, I would think that when powering the module that the voltage would be more like 2.9V or less. The voltage sag could be dramatic depending on the battery chemistry.
