BB750 Input Voltage?
Otokoyama
So Cal
The specs say Maximum Input Voltage 9V but Input Voltage Range (5W) ~4.0-6.2V.
If I drive a 5W with 5 NiMH cells (7V fresh), will anything fry, or will the emitter just be overdriven (i.e. direct drive) for the first few minutes?
i believe you just need to keep it under the vf of the led.
any more can kill the converter i *think*
You can go above Vf by a few tenths of a volt. Beyond that you could damage the converter board. 7V is probably safe depending on the Vf of the 5W.
Wayne
Thanks, for this response and in the other thread.
So it sounds like 6 NiMH cells would actually be too much regardless of what the Vf of the emitter is. Right?
6 NiMH is asking for trouble. NiMH hold their voltage well under load and a fully chaged NiMH battery is typically 1.4V or so. That would put the stack of 6 batteries around 8.4V which is well above the Vf of a nominal 5W LED.
I know that makes it harder on the battery arrangement and configuration.
The only other alternative is to use a step down with 6 batteries like the Downboy or use a stepup/stepdown converter. The wizard is a stepup/stepdown but cannot handle the power requirements of the 5W.
Wow, I was planing on run the BB750 in a 6 C cell with a 1W. Is 6 C alkalines’ to much voltage? My understanding was that maximum 9V meant that 6 X 1.5 was ok
K, I see that 3.1V is the maximum voltage for a 1W. What is the best way of getting the most light from the 1W/6C combination then?
Thanks!
Chief Wiggam thank you, but I just don’t get it. I understand why I would need a DB vs a BB for my 9 volt project but I don’t get why a 400mA DB would be brighter than a DB700. I’m sure the answer has to do something with sense resistors, but I don’t understand. Is there a Down Boy blank tread for dummies somewhere?
Thanks,
Dave
Have a look at the calculator web page I created to compute the sense resistor and now it computes the estimated run time and suggested converter board as part of the run time calculation.
www.anlighten.com/shop/test.php
It is still in development. Use at your own risk.
Wayne
Thanks guys, I think it's starting to sink in. What's the Battery Amp/Hr capacity for standard C cell alkaline?
Dave
