geek4christ
I recently received my BC-900 and proceeded to put 4 cells in it on refresh mode. These are old (maybe 4 years or so) Energizer 1850mAh cells that have been severely neglected since I bought them.
The refresh cycle has finished on all 4, and I ended up with capacities of 1776mAh (~96%), 1893mAh (~102%), 1943mAh (~105%), and 1834mAh (~99%).
My question is, did I actually end up with overcharged cells or is the BC-900 just not very accurate in its readings?
I have the charger plugged into a surge protector with noise-reduction, and I have a very small fan blowing on it. I wanted to try charging with the fan because I don't want the cells hitting the high-temp cutoff. I want a solid current going into them until -dV is obtained.
Having said that, I'm not really sure what the charging voltage profile of cells that are this old and neglected would look like, so I'm wondering if -dV occurred in overcharge.
Any thoughts or recommendations are much appreciated. And, as always, please be gentle on the newb
