Putting a P4 and a 5 mode driver in a 2D maglite. I was thinking about sleeving up 2 18650 batteries but it's too much juice for the driver to handle. Any Ideas????
I have not checked on your driver specs but if it is too many volts (in series) then you could try another configuration. Is there enough room to put the 2 18650 cells side by side and run in parallel (same voltage as 1 cell but twice the mAh capacity for long run time).
If there is not room to place them side by side, you can always place them stacked using a custom battery holder which will still connect battery1 + to battery 2 + and the battery1 - and battery2 - together so basically they are still in parallel.
