Corvette6769
- Joined
- Apr 28, 2009
- Messages
- 130
- City & State/Province
- Central Illinois USA, In a van down by the river
I have searched this forum for over 4 hours and find very little reference to the actual equipment/software being used for the various battery Li-ion shootouts, tests, and run-times posted here.
In addition to my Ultrafire WF-138 and WF-139 chargers which seem to work well for charging my Li-ion CR123, 10440, and 18650 cells, I have several high-end chargers including a Maha MH-C777PLUS-II Universal LCD Charger - Analyzer - Conditioner.
Problem is that when the battery's internal over-charge and discharge protection activates, my Maha charger resets and I loose all data, so I have no way to judge the actual discharge capacity of protected cells.
Moreover, the Maha charger stops the discharge cycle between 3.2 and 3.4 volts, stops charging at 4.1 volts, and the discharge rate is fixed at 300mA, so I have no way to do testing at various volt ranges (2.8 to 4.2v) or current rates, like the tests I see posted here on the forum.
I have several different 18650 batteries I would like to test at various discharge rate intervals between 300mA and 3 amps so I can determine which specific battery is best suited to handle my Cree MC-E that draws 2500 mA and which are better reserved for use in my less demanding Cree XP-E flashlights.
What is the best discharger / analyzer for testing protected cell batteries?
