Best LED for Flood?
Aepoc
New York (not the city)
I'm currently designing a multi-function flood and spot light. I will be using probably around 6 XML LEDs with small reflectors for the flood function, but I'm not sure what LED would work best for spot. I am hoping to use an aspheric lens with whatever LED I choose for spot.
What LEDs provide the best throw when used with an aspheric lens? What size lens would give me the best throw/size ratio? Is there any optic out there that would provide better throw than an aspheric lens?
You are looking for a LED with the highest sufrace brightness relative to surface area. Currently the best in that reguard is the XR-E.
Generally speaking irreguardless of lens type (aspherical, TIR, parabolic reflector) the larger the lens the greater amount of throw (hotspot lux).
XR-E was what I was thinking... Nothing newer has come out yet? Has anyone found a good way to use multiple emitters as spot... say three XR-Es with some sort of optic? My experience is that any time multiple emitters are used, its difficult to get a nice collimated beam. My concern with using a single XR-E is that the output would be insignificant when compared with the multi XM-L array...
a spotlight made from multiple XML will need a very complex (math-wise) deep reflector, or aspheric lens, or both,
or multiple lens layers....
doable, but it is gonna be costly to get right
Okay, so here's the configuration I am considering:
I'm not sure what to do to get the most throw out of the single XR-E in the center... My original idea was to use small reflectors for the XM-Ls to provide the flood and a small aspheric lens (~20mm) for the XR-E. I'm worried that the small aspheric lens won't provide enough throw...
I have been tossing around the idea of using a single large aspheric lens to cover all of the LEDs; My goal being to center it over the XR-E to provide maximum throw. If I went this route, I would not use reflectors for the XM-Ls. My question is: What would the large lens do to the light produced by the XM-Ls? Would they still provide flood in this scenario, or would the aspheric lens somehow collimate their light even though they are not centered?
