Best Li-ion charger?
krayzeemofo
Hi, I was wondering if there was a best Li-ion charger. I've looked around and there seems to be a couple that are referred to every once in a while, namely a trustfire model and an ultrafire one. I've seen that the trustfire one, http://www.dealextreme.com/details.dx/sku.4151, can charge many types and its less than $10; is there any other one which might be more reliable, or is a 'smart' charger?
Thanks in advance :)
I have been using the pila ibc charger for a month or 2, and it does an excellent job at charging my pair of wolf eyes 18650's and 1 aw 17670 li-ion cells that i have. It uses the recommended charging algorithm . Those chargers that you mentioned might be ok to use as long as you have some quality protected li-ion cells such as wolf-eyes,pila, or aw.
I also own the Pila IBC as well, I highly recommend it.
If you want to purchase an inexpensive Li-Ion charger from DealExtreme, I might suggest the WF-139. Decent charger with more flexibility regarding charging different size cells. It was my first Li-Ion charger, and I still use it for 14500 cells.
I saw that one the other day. I almost bought it, being the charger junkie that I am, but a couple folks mentioned that their 14500s wouldn't fit into the slots.
Based on the pictures I'm seeing of this charger, looks like a pair of these spacers would take care of that problem. I use these same spacers to charge RCR123A cells in my WF-139.
I can't comment on whether its better than the Pila in terms of charging, my hunch would be to say no.
thanks.
I don't see where I can purchase that Pila charger, so perhaps the shoshine is the next best bet?
There is a group buy for the Pila IBC charger going on here if you want to save a few bucks :thumbsup:
