- Joined
- Jul 15, 2021
- Messages
- 49
The ALP128 LED light channel with a diffuser is designed for cove lighting. It has an aesthetically pleasing appearance and comes with a PC diffused cover to diffuse lighting evenly, creating a uniform and even light effect. The aluminum LED profiles are made of 6063-T5 material and have white powder-coated surface treatment and anti-oxidation for a longer lifespan. The standard length is 2M per piece and can be cut to any size. The inner width is 18.7mm, allowing the maximum width of strip lights to be 18mm. You can install single-line or dual lines of LED strips as the light source. Only one type of diffuser is available: PC opal matte diffuser; they are made of stable material, anti-yellowing, and provide an even light distribution. 90°,90° vertical, and 180° couplers are available; you can use them to connect the LED light diffuser for a longer continuous one. The drywall LED channels with flanges have honeycomb holes that are easy to recess in on the walls for trimless installation.
Link: LED Strip Light Diffusers
Features:
Features:
- Model: ALP128
- Material: 6063-T5 Aluminum Alloy
- Surface Treatment: White Powder Coated
- Colors: White(Default), Silver, Black
- Size:95.7*35mm(H*W)
- Inner Width: 18.7mm
- Compatible With 3528 Or 2835 LED Ribbon In Double Rows/ 5050 Strip Light In A Single Row
- Max Power: 15W/M
- Standard Length: 1M
- Other Lengths Available: 0.5M, 1.5M, 2M
- Custom Length Available: YES
- Diffusers: PC Opal Matte Diffuser (78% Light Transmission)
- Installation: Drywall Ceiling / Wall Plaster-in
- Application: Architectural / Cove / Indirect / Accent Lighting
- End Caps With Wire Holes Included
- 90°, 90° Vertical And 180° LED Channel Couplers Sold Separately
- 5 Years Warranty
