From FlashlightConnection Dereelight DBS V3 3SM Cree XM-L Flashlight description:
http://flashlightconnection.com/Der...ons/DBS-V3-3SM-Cree-XM-L-Flashlight-p379.html
Also Farther down:
Now in the Thrunite Scorpion V2 review by Selfbuilt, It seems Thrunite boosts the power of the light to 3A with 2XCR123 but forbids RCR123. Selfbuilt explains it here:
http://www.candlepowerforums.com/vb...Turbo-Head-Review-RUNTIMES-BEAMSHOTS-and-more!
The lights seem to have contrasting warnings. The RCR issue is pretty much explained in the same way by both. Using them will degrade them quickly thus making them more unstable and possibly posing a hazard over time. I guess the real question is, are primary CR123 safe for powering an XML emitter at 2.5A and above? Or is this just a matter of opinion and debate?
*Although the DBS V3 XM-L can work with 2xRCR123 batteries, their use is highly discouraged... they're just not made for the high current draw that this light places on them. Their lifespan will likely be significantly reduced, and it could even present a fire or explosion hazard.
Also Farther down:
WARNING: Do not use 2 x CR123 3.0 volt non-rechargeable batteries, they are not designed to withstand the current load that this flashlight places on them. Using them can result in a fire or explosion hazard.
Different chemistry again. Primaries can handle quite a bit in some regards, but also have their own limitations (i.e. they can get quite hot internally). But real capacity is higher than protected RCR, so discharge rate is lower. Still, I wouldn't recommend running primaries on Max for extended periods either (mainly for heat) - 18650 would be the best way to go.
Rechargeable Li-ion chemistry has different needs, and care has to be taken in how you treat them if you expect them to retain a charge (and retaining charging ability). I wouldn't be surprised to see >4C discharge rates on standard protected RCR here (and no, I'm not going to test it - I go through enough cells as it is, without that abuse :rolleyes:).
