Not a huge suprise I hear you cry
At work last night I dopped my late shift belt light (6P head, 2 x 18500 Leaf C-C body with 2 of AW's protected 18500's running a LF HO9 bulb) down a flight of stairs (concrete covered in lino) and watched it clatter into the corner to be stopped by the wall :crying:
It still worked when I switched it on but very yellow, I swapped the batteries out and back to normal. I had not used it much last night and the 2 cells read 4.11 and 3.73V when tested this morning. The 3.73 volt will not charge up on my new Pila charger so I have heaved it in the bin and ordered some more
I read the instruction book for the Pila charger and it stated that a faulty battery would give the green LED solid and the red flashing rapidly. On mine both reg and green were on constant. I didnt think it was worth the risk of beggering about with it.
I drop my lights with horrible frequency but this is the first time I've had a battery go on me. I've reported here before that a Pila G3 of mine has 2 big chunks out of the reflector from drops and still works fine
